I’d like to make a voltage sensor wire for the MultiPlus II. I know I need 18-20AWG wire (I have 18AWG) but what length ferrules do I need? Pin length 15mm? The pin length on the temperature is about 19mm. Thanks in advance for your help.
lxonline
(LX)
2
Use the same pin length as the temp sensor.
Thanks for your help.
Related topics
| Topic | Replies | Views | Activity | |
| MultiPlus-II AC Connections | 1 | 265 | 7 January 2026 | |
| Install voltage sense wires on Multiplus II | 4 | 230 | 26 May 2025 | |
| MultiPlus-II AC terminal ferrule length (fine-stranded cable) | 1 | 179 | 7 November 2025 | |
| Proper way to connect 10AWG AC line into Multiplus 2 | 21 | 673 | 16 March 2026 | |
| Multiplus II 48/5000 Screw Terminals are Back! | 4 | 290 | 10 January 2025 |
