Lynx distribution lights all red
I have finished my install of the system:
Multiples II 24/3000/70
Cerbo gx with 70 screen
Lynx shunt 1000
Lynx distributor 1000
2 Litime 24v 230ah
24/12 dc converter
I have the following issues, green light on shunt all red lights on distributor, no SOC on screen. Everything else is working great. In troubleshooting I removed all the fuses from the distributor just to see if the fuse lights would not illuminate red and get green power. All lit up red.
Any suggestions greatly appreciated.
It also happened to me that all the lights on the Linux distributor were red, but the fuses were intact. I solved it by restarting the system.
I’ve tried that with same results. Powered it up with no fuses across bus bars and same thing. I disconnected the wire from shunt to distribution and same thing. Strange thing is everything works when hooked up.
But are the lights off now? I didn’t remove the fuses from their location, I just restarted the system.
Yep now only 3 red lights
I imagine that where the red lights are on, the fuses are inserted because if there are no fuses of course the lights will be red. I restarted the entire system by disconnecting the Cerbo GX from the power supply
I just finished turning everything off and unplugging the cerbo. Making progress when back on, now only middle 3 lights are red including the power. Everything is working. I wonder if all 4 locations need a fuse.even though nothing is on those legs??
Yes that’s how it works you need fuses on all four to get a single green light in the middle indicating no problems
Thanks, have fuses on order to put in place
