Lynx BMS & Skylla IP65 two manual switch in addition to ATC on REM
I have connected the Lynx BMS NG ATC contact to the Skylla IP65 REM contact so that the BMS can block the Skylla from charging if required.
Unfortunately the Skylla is not really integrated in to the GX ecosystem and can only be monitored and not controlled.
There are times that I want to manually stop the Skylla IP65 but the REM port is in use the BMS ATC contact.
My question:
Can I put an additional manual switch in the cable that connects the ATC and the REM? Or even better can I loop it over to the Ekrano GX relay contact so that at least I can operate it from the Ekrano Screen? I have trained my users to go to the new gui to turn on and off the inverter there, so it would be the same for the Mains charger.
Your help and advice much appreciated.
Alex
Yes you can add a switch or pass it through the Ekrano relay.
Thanks for the confirmation. Do you know if its possible to rename the Ekrano Relay names in Venus os 3.53?
You can not rename them. This is a much requested feature.
