Low Volatge
Hi
Got Multipluss ii 3 phase system with Pylontech Batteries, getting low voltage alarm, at 48.40 volt, the low voltage in inverter is set to 47v, but its only on the remote console.
Is it the ve bus sending the alarm or the pylontecs them selves?
HI
i am not sure? how do i know?
Maybe post what you are seeing here.
On the GX the error message will state what is triggering it.
And on the vrm if it is logged online.
Do you use ESS?
Check the Dynamic cut-off settings (this example is a 16S batt)
