i’m a beginner with Victron products and not very good with electrics.
I hope somebody can help me here because the shops where is buy the parts can’t help me..
Components in my setup on the boat:
lead/acid startbattery 12v
lifepo household battery 12v
Orion-Tr 12/12-18A (220W) Isolated DC-DC converter
smartsolar mppt 75-10
2 Solar Panel 30W-12V Poly
System in my little boat from engine to battery’s:
Outboard engine to startbattery
Startbattery (lead acid) to Orion-Tr 12/12-18A (220W) Isolated DC-DC converter
Orion-Tr 12/12-18A (220W) Isolated DC-DC converter to lifepo household battery
2 solarpanels (30w each) to smartsolar mppt 75-10
smartsolar mppt 75-10 to startbattery.
My idea was to have both batterys always full when the boat is in the harbor and the solarpanels are connected.
Problem what i find is: the solar panels charge first the lead/acid start battery, if he is full the orion opens to the lifepo household battery. The voltage from the lead acid battery drops because the lifepo battery can handle a lot of electric energy from the start battery.
Voltage drop battery in a few seconds to low so the orion shut the conection between the 2 battery’s down. and the process starts again and again………
New idea to connect:
A solar charger works the best on lifepo battery’s. Is it an idea to connect the mppt 75-10 direct to the lifepo battery and connect the lead/acid start battery to the “load”output from the mppt 75-10.
If the voltage in the lifepo is high enough than he opens the load output to the startbattery?
And if it getting to low het shut the connection off.
Or is that wrong/impossible? And have somebody a better idea?
Gr Jelle
