Installed Orion XS 50Amp DC to DC charger a couple of weeks ago (thanks for all your help!). Seemed to work flawlessly until today. When leisure battery was below 80% it charged at 40+ amps and 500-600 watts. When the battery was 80+ % the charging slowed down as expected. Engine off – Orion off. Perfect.
Today it was strange. Although battery stated it was 67% on the Victron BMS, the Orion would only charge at 200 watts and about 15 amps. The unit was not warm.
I have an NC3 V6 Sprinter from 2008 and have used the “Regular” alternator setting. I have a voltmeter plugged into cigarette lighter to see starter voltage (when running and when off). Voltage goes up nicely when engine running.
As another test, on the Orion APP, I disabled the “Engine shutdown detection”. Immediately, the charge went up to 600 watts and 45 amps. One error I did get was the “Engine shutdown detection”.
The leisure battery is new and when it was first 100% charged, I set the Victron Smart BMV battery setting to “Synchronize SOC to 100%. I notice today that the Smart BMV reading jumped from 67% to over 90% for no apparent reason. I have thought of resetting the “Synchronize SOC to 100%” again once I have fully charged the battery at home.
Any help would be appreciated, as we are off on a big trip in 10 days.
Seems like the Orion is working as it should but something wrong with a setting??
Thanks in advance. Ian
