Lithium battery charging
I want to know if the victron lithiun 24 volt batteries have similar charge parameters as lead acid batteries in an inverter?
You can view the charging parameters and other requirements of Victron LFP batteries through their product page(s); you don’t specify which Victron LFP batteries, but assuming let’s say SuperPacks since you don’t mention BMSs, here’s the datasheet for those which includes charging parameters: https://www.victronenergy.com/upload/documents/Datasheet-12,8V-&-25,6-Lithium-SuperPack-EN-.pdf
