Line CAN bsm to multiplus GX
Hi everyone, how can I see my Yilink battery in CAN to the Multiplus GX inverter?
I’ve already connected the right cable, but despite changing all the protocols available
on the remote console, the GX module doesn’t see the battery CAN.
Do you have any advice? Thanks everyone, thanks everyone bye.
Hi its an “unsupported” battery, its not on the compatibility list, so you should ask the manufacturer how to set it up
it might have an “supported” bms that can be set at a protocol that could work
Hi, the supplier told me that it has the same protocol as Pylontec, but I don’t know what it is.
do you know which one it is? thank you
Then take a look at this document:
Section 3
Thanks so much, I also tried the ones you told me about, but unfortunately it doesn't see it...
Do you know the canbus pinout of your battery? Is it correctly connected to the GX
