I have a waveshare USB to RS485 coverter. I know the pins to connect to the PC, A+ pin 2 orange and B- pin 1 white/orange. I would like to connect the BMS 1 amp balance 150 amp inverter model to the USB on my raspberry pi running venus os. Can I use the same wave share but with GND pin 3 white/green, CAN-L (B-) pin 8 brown and CAN-H (A+) pin 7 white/brown. Using the 2nd ethernet port on the left of the BMS and setting it to victron in the bms software. I’d like to use the JK BMS as my battery monitor in venus OS.
Related topics
| Topic | Replies | Views | Activity | |
| JK Inverter BMS to Raspberry pi Venus OS | 1 | 1280 | 18 October 2024 | |
| Venus OS auf Raspberry PI mit JK BMS | 8 | 181 | 30 June 2026 | |
| Can Hat RS485 to JK-BMS | 0 | 83 | 2 February 2026 | |
| Venus OS 100 Balance BMS | 8 | 895 | 10 June 2025 | |
| Nkon Ess -> Venus Os | 20 | 558 | 2 February 2026 |
