System consists of Cerbo GX v3.50 with:
¹) SmartShunt IP65 500A/50mV
¹) Smart Phoenix Inverter 24V 2000VA 230V ¹
²) Phoenix Inverter 24V 1200VA 230V
¹) Phoenix Inverter 24V 500VA 230V ¹
¹) Phoenix Smart IP43 Charger 24|25 (1+1) ¹
³) SmartSolar MPPT VE.Can 250/100 rev2
Power bank is 24V 200Ah lead acid with IP65 Smart Shunt being the only connection on the negative, devices are connected to GX using ¹) VE.Direct, ²) VE.Direct through a Duppa 4-Port USB converter and ³) VE.Bus.
Issue #1 VRM Installation data “Solar” does not show any “direct use”, while it is clearly happening according to the data of charger, shunt and inverters
Issue #2 IP43 charger is showing up both under Inverter/Chargers (with correct custom name) in GUI v2
and under Batteries (with wrong name “Charger”)
with the Animation direction for power flow when charging being wrong
and the amount of power delivered from the grid to the system is not accounted for at all, in the Installation data statistics of VRM:
This is a 500€ device… ![]()
Issue #3 The Phoenix Inverter 24V 500VA 230V generates a low battery alarm each time it is shut off through opening the remote enable (wired to the NO relays of both MPPT and mains charger, so it’ll only be active if solar or grid power is available and not drain the battery)
Issue #4 Smart Phoenix Inverter 24V 2000VA 230V (in VRM and GUIv2)
is according to the label and Victron Connect App in reality a 24/1600
Issue #5 SmartSolar MPPT VE.Can 250/100 rev2 does not deliver set float voltage, but 0.2V below what is configured. That might be caused by temperature offset, but as the used Temperature is not shown anywhere that is guesswork.
(oscillates +/- 0.02V around 27.4, instead of the 24.6 configured)
Issue #6 SmartSolar MPPT VE.Can 250/100 rev2 (configured for VE.Smart network, to use the data from the shunt) reports “Battery current”, which (according to the shunt and inverters) is the total output and not what it is delivering Interaction with “the battery”
A better description could help here.
Issue #6 SmartShunt does not detect charge cycles (but recognizes sync to full on charging end)
Now the big question:
Where to report all this best, so it can (and hopefully will) get fixed?
