EcoWorthy Batteries and Victron: Getting power history to display properly
Hi all,
I recently installed a set of EcoWorthy Server Rack 48V 100aH batteries with my Victron system (Cerbo Gx, Multiplus-ii, and others). These batteries talk with the inverter over CAN (using a “Victron” protocol as selectable over the app, or other compatible protocols like “Pylontech”).
Generally everything works well for the most part - CAN packets are accepted, the touch screen shows correct info for the battery (voltage, current, etc). The battery was successfully configured to control charging, and to be used as a “Battery Monitor” on the GX and VRM. The one problem I am facing is that on the VRM Dashboard, the graph showing historic consumption/production is not correct. Instead of showing actual consumed energy, the consumption graph always shows a graph total power input (it is always equal to solar+shore regardless of what the actual consumption was). Here are two graphs showing that consumption=production, while at the same time the battery capacity is changed (because consumption was not actually equal to production). One is solar-only, the other shows solar+generator=consumption when generator is run:
Note that switching the “Battery Monitor” to be my Victron SmartShunt fixes this issue. I spoke with both my Victron Dealer and the battery manufacturer. The Victron Dealer pointed out that the battery history page from the EcoWorthy Battery does not show history, which may be causing this, but they do not know for sure. The Battery manufacturer says they do not know how Victron calculates consumption, and that they do not get support from Victron engineering and believe their protocol is correctly implemented, but would be happy to work with Victron on a correction if they had a way to get in touch.
For now I am using the smartshunt as the battery meter to work around this issue, however the battery meter and the actual battery do not always agree on the battery percentage, and it’s annoying to not be able to display the actual batteries report of the state of charge and instead have to be constantly toggling between the two. I’m looking for advice on how to correct this issue (or if the correction requires a protocol change from EcoWorthy, how I can help get them connected with Victron support to update their CAN protocol).
(Edit): I took a look at the Victron document VE.Can Registers Public, and am wondering if the historic data is populated by the registers defined in Section “1.16 History values (new)”. But this section is defined as “Read Only”, and I would expect it needs to be “Read Write” for the battery to be able to populate these.
Below is a screenshot of the Battery’s history page on the GX device:
How can I get some help with this? I first tried going through my dealer and they were unable to help with this and could not refer me further. I tried working with the battery manufacturer and they could not help because it required assistance from Victron which they were also unable to get. I tried posting a detailed thread (read above) and had no engagement.
It’s very frustrating that there is zero path forward to get this resolved with Victron or even hear back, and that it’s not something that can be resolved by a dealer. I hoped for better support when investing in a Victron system rather than going with a cheaper competitor.
@pwfarnell @guystewart Tagging you because you seem to be active in the forums and work at Victron. Is there anyone that could help with this? It seems like a small change or providing info to the battery manufacturer would fix this, but it has not possible without any support from Victron.
I am not a Victron employee, like most of the active members of the forum I am a volunteer as explained in the community guidelines. I am afraid your question is outside my knowledge as I only know Victron batteries.
Try to use serial battery from github for your bms Looks like your bms didnt talk the right protocoll and the two datas comes only from the bms.
only the bms can realy say how many kwhs are going over it in and out.
@Maik I am talking with the battery manufacturer, who is interested in creating a firmware update to make their BMS talk the protocol correctly, but it’s unclear from the Victron documentation what is needed. As I pointed out in my first post, the protocol for the battery history is read-only from Victron, not a write command.
@pwfarnell sorry I thought I read on your tag that you worked at Victron, my bad! I read the guidelines but was not clear how I can get the support I need since I followed all the pathways offered and hit dead ends.
@gribov42
They aren’t doing anything out of the ordinary for the can protocol there are guys on gut who have workong drivers with correct addresses to communicate fully.
Here is a good start read. From the old community.
And a technical paper openly available
Hi @gribov42,
The list of batteries that have been tested and known to be compatible with Victron Energy are here - https://www.victronenergy.com/live/battery_compatibility:start
I am working on expanding the promotion of batteries that have completed the full BMS-Can specification compliance tests.
The process for a manufacturer to get their battery into the program is via the regional Victron sales manager - they can be contacted here - Contact - Victron Energy
The sales manager will review the request from the manufacturer, and if they appear to be a good fit, will write them a recommendation to Victron Energy R&D team to start the process of receiving the latest specification and testing protocol.
That should be enough to get you started, and if that proceeds should connect the manufacturer to the engineer who can help them with that history register issue.
Thank you,
I seemed to have missed this last message but will forward this info to them.
For now I am making up for this by using a Victron Smartshunt as my primary monitor, which works and gives me most of the feature needs. But there seems to be some difference in offset because when discharging slowly over time the battery hits zero percent faster than the smart shunt.
Is this a case where I should do a zero current calibration? Or should I just occasionally reset the Smartshunt SOC to match the battery?
Pics of offset issue:
Google Photos
Your experience is exactly why we do not support customers that want to bring their own batteries to a configuration. Most of the so-called “budget” batteries have shitty BMS’s. Many of them advertise compatibility with Victron, but most of them haven’t actually done all the testing. If the battery shows up in the Victron device list they claim success. I have tested MANY third party batteries with Victron systems and even helped get one on Victron’s 3rd party compatibility list.
I’ve heard this so many times that I’ve come up with the following analogy. Some people buy a premium car that requires premium fuel, but put in regular fuel to “save money” and then complain about the experience. I have heard more times than I can count that people want Victron because it’s a high quality product but then want to “save money” by buying Big Bubba’s Cheap Battery to go with it. It just makes no sense. Buy once, cry once. Or, more elgantly stated by Ben Franklin “The bitterness of poor quality lingers long after the sweetness of low price is forgotten.”
Consider asking for a refund on those batteries and then go buy something on Victron’s 3rd party battery list. It’ll just work. Pytes V5° batteries would be a good choice for you to consider. Plug them in, the Victron GX device recognizes them, and configures all the DVCC settings. It’s just that easy.
I’m also going to use eco worthy batteries, can the 250 kbit/s or 500 kbit/s setting be causing the issue?
This is what Victron said:
Battery communication and CAN settings:
The Cerbo GX MK2 does use isolated CAN ports, which is expected for the newer revision. That part of your setup is normal.
At this time, ECO-Worthy 48V server rack LiFePO₄ batteries are not listed on Victron’s official compatible battery list. Because of this, we’re unable to confirm whether CAN communication can be established between the batteries and the Cerbo GX.
Specifically, we cannot verify:
  • Whether CAN communication is supported with Victron equipment
  • Whether the batteries require 250 kbit/s or 500 kbit/s
  • What charging limits or BMS data would be passed over CAN
Those details are determined by the battery manufacturer, and since we do not sell or test ECO-Worthy batteries, we aren’t able to advise on CAN programming or configuration for them.
I recommend reaching out directly to ECO-Worthy to confirm:
  • If their batteries support Victron CAN-bus integration
  • Which CAN speed is required
  • Whether they provide a Victron-compatible profile or setup documentation
I also found this
  1. Disable Advanced Monitoring: To prevent SOC drift and get more stable readings, disable “Advanced Battery Monitoring” in the Cerbo’s settings for that battery.
Fair enough - But I understand that Victron cannot take responsibility for these batteries. I was a bit frustrated that I wasn’t able to find anyone within Victron support to talk to at all about the Victron protocol and what parts of the protocol are used to populate certain charts in the VRM portal. Though I now got the support I was looking for in the comments above yours, which I have sent to EcoWorthy to hopefully push them to fix their issue (I am doubting they will for the reasons you mentioned). Generally though I will say the batteries were mostly plug and play - DVCC and all other features worked off the batt, I just have this one issue with the battery history (and it being necessary to generate statistics in VRM).
EcoWorthy does provide a Victron profile (and their “Pylontech profile” seems to work fine as well). I don’t remember off the top of my head which bitrate it used but it was correctly configured and worked plug and play immediately. Generally all features that I’ve checked are available except that the EcoWorthy does not report battery history, which appears to be used by the VRM portal for some statistics.
Although the root issue is that EcoWorthy does not report battery history, one thing that I’m still curious about from the Victron side - Why is the battery history report necessary to populate the consumption/solar chart correctly? The battery is clearly reporting current/voltage (as I can see from the charts) and that should be enough information to integrate and generate this chart. I’m not sure why in the absence of this CAN packet the VRM portal generates an incorrect chart, rather than showing no data, or using the other info available to generate a correct chart. This perhaps is something Victron might want to consider updating. @guystewart for visibility.
I’m genuinely glad to hear that. Please come back in 6 months and give us an update on your experience. That could be helpful for others in the future.
I have lead acid batteries and Victron’s instruction is to find out what the tail current is from the manufacturer, then program that into the MPPT’s and the Smartshunt. Also to know the C10 and C20 rates and put those parameters in too. However during the winter there is usually a discrepancy, ie. to indicate 100%, my tail current @59 volts is around 28 amps. If, during winter, the absorb phase ends at 59 volts 37 amps, I think my batteries are probably around 95% full, but the system won’t move the percentage until the 28 amp threshold is passed. So I manually reset the SmartShunt to 95%. I don’t know what the indicators for Lithium batteries are, I’ve not looked into it. But I’m confident about working this way because I know the charging characteristics of my batteries.
