Issue EM530 with split phase
I am doing an upgrade on an older yatch from 1982.
The vessel has a split-phase system.
Have installed a 8k Quattro on the shore power (AC in 2) and the generator (AC in 1). The output is going through a Autotransformer before the load. I have energy meters on both shore power and generator in case to load is being run in bypass mode outside the Quattro.
The issue I am having is that the energy meter EM530 is not being displayed correctly. The Ekrano changes the setting for the meter to 3PN, from the setting it should have, 2P (split phase), and it shows to much “AC loads”. Seams to be twice as much as it is. If I disconnect the meter, the GX displays the correct “AC loads”
Has anyone else any experience with this configuration?
Here without energy meter
And here with energy meter
Think I have figured it out.
It seams it takes the L2 W on grid, and just transfers it to L2 on AC loads..and adds this to the actual load…
Does anyone know a workaround on this?
