New install in US. My shore powers voltage is 125.7 and the output is 134.1. Is this a problem? When I get to EU and switch the input jumpers what should I expect?
In marinas with chronically high shore voltage (e.g., 130–135 V in the US or >245 V in the EU), the standard boost can push output too high (e.g., your 125.7 V in → 134.1 V out, or worse under light load). Bucking brings the output closer to (or slightly below) the input, protecting sensitive equipment like MultiPlus inverters/chargers that may cut out above ~135–140 V on 120 V systems or equivalent on 230 V.How the Reconfiguration WorksThe transformer has two half-windings on the primary side and two on the secondary side. The standard boost configuration connects them in a way that gives the slight step-up. To buck:
Owners swap the primary winding connections with the secondary winding connections (typically four specific spade terminals).
One commonly reported swap for the 2000W model (and similar on 3600W) is moving the wires at these points:
Swap J18 J30
Swap J15 J27
Swap J16 J28
Swap J11 J26
After swapping, the terminal order (left to right) becomes something like J30 / J27 / J28 / J26 on one side and J18 / J15 / J16 / J11 on the other (exact order depends on your unit’s layout).The input and output voltage jumpers (for 230 V in / 120 V out, or whatever you choose) stay the same as before.
This is not in the official Victron manual and is a DIY modification done at your own risk. It does not void the warranty in all cases, but Victron support may not assist if issues arise after the change.
