My AC shore power is 235V 50hz. the unit’s jumper are configured to output 230V.
When I check with a voltmeter I get 250V 50hz. After a few minutes (sometimes 5 sometimes 20), the 16A breaker on the shore power trips (not the gfci, I’m talking about the individual breaker protecting the circuit from overcurrent). The transformer is 3kw so 16A is plenty (and I wasn’t drawing any current from the boat anyways).
If that helps, on the boat end of the transformer there’s a multiplus and a BMS NG, but that part should be.. er.. isolated ![]()
what could be causing this?
Thank you!
Brann
