I have a Victron system on my sailboat that includes an auto switching isolation transformer. The boat is a 230V/50Hz boat. Power is coming into the shore power connecter at 127V, being doubled, plus the extra 5% provided by the isolation transformer, to become 267V.
The voltage is briefly observed to be over 270V by our dual Multiplus configuration, so the switch-over to shore power does not happen.
While the intent of boosting 5% is a excellent solution in a lot of cases, it is a killer in other uses where incoming voltage is already higher than it should be.
If this were not a smart, auto switching transformer, swapping connections around to instead create a 5% buck would be straightforward. Since this model is more complex, including the ability to sense and adapt to the incoming voltage as well as use a soft-start feature (which probably doesnât actually do anything when feeding a MultiPlus), that change is not so obvious, especially without a real schematic.
If the toroid transformer inside has a dual primary windings and dual secondary winding (with 5% more number of turns, swapping each input wire for each corresponding output wire should accomplish what Iâm looking for. But, again, without having the schematic, it is not possible to know for sure.
Can anyone help on this topic so I can correctly change my autotransformer to a 5% buck?
Thanks,
Mike
