Anybody knows where to find the plastic isolated mounts used to wall-mount older Victron equipment like isolation transformer and Skylla battery chargers?
ID is 10mm, OD is 28mm, they are fitted from both ends of an 18mm hole in the casing, and they protrude 10mm of each side.
Otherwise, any alternative that doesn’t add more than 10mm between the casing and the wall and accepts M8 or M10 screws?
I’ve been looking for a solution for 2h already but couldn’t find anything I like.
I’ll say that “originals from Victron” isn’t so much a concern; Victron’s factories no more produce little plastic widgets like this than they do the mounting screws that come with many of these things.
You could certainly try calling around to your local distributors and see if any of them have some saved off of RMA’d units or something like that, but honestly I doubt anyone would have bothered saving something like this… up to you if you want to try though!
I certainly don’t care for original Victron mounts I do have very limited access, though, and can’t fit the usual rubber mounts that are available everywhere.
If anybody is looking for similar parts, the keywords seem to be “bonded mounts” or “mushroom mounts”.
