Is there any way to change the layout
Hi all A newby. Is there a way to change the VMR layout. There are AC items on it and i do not use them. I am totaly off grid so solar panels then mppt chargers amd then a batterij whith a shunt so that i can messure the battery. Leg me know please
No, it is all automatic. This is an oft requested feature, one day it may get added.
VRM itself does not really let you rearrange or hide those blocks today. For a Cerbo/VRM screen, the answer above is right: you mostly get the automatic layout. If the goal is just a cleaner local display for an off-grid setup, a separate phone/tablet dashboard can be a better fit than trying to make VRM into a custom panel. Disclosure: I build Boardstrom, which is aimed at that local Victron dashboard use case, but for configuration and remote monitoring I would still keep using VictronConnect/VRM.
