IOS Watch vrm missing Load
Hey
I used to have it but now it appears and then dissapears.
And after that load is missing.
If i kill that app then reopening it i ca see load for half a second:)
In vrm app i have load visible anf displaying correct value.
Still not fixed by victron???
Or do only I have this bug?
Same here!
This was fixed ages ago. In some cases it was caused by a gx setting for where the inverter loads are located.
Are you on the latest app?
Version 3.0.37
Check what your gx setting is for location of inverter loads.
It was set to “AC output only”; when I switch it to “AC input and output,” it works.
Is that the correct way?
Indeed. Seems to make everything work and has no effect on system behaviour.
This was marked as the solution for a similar topic.
All right. Thank you very much.
FYI, the cause has been identified and this will be addressed in an upcoming release according to team VRM.
