Inverter side of Multiplus II is not coming on
System comes up and sees my batteries and starts to charge – batteries are about 50% right now. AC input is present and passing through to AC-1. The charging LEDs are correct. The inverter LEDs are all OFF! Any suggestions?
Without knowing the system setup / settings, be aware that either the inverter is active or the charger and when charging from AC, loads will be fed from the grid.
Just got back in from the garage after making it work (I will not say figuring it out). I did an MK3 update and things reset and it all started working. I will be posting about my system next - once the pictures get uploaded.
