The inverter is turned on, however the Cerbo indicates it is off. I am getting 120 out so I know it is on. the inverter is a multiplus -II 24v, 3000vva 70 amp 120v inverter. I also have a Cerbo gx connected to it. This worked for 6 months but last night it started behaving strangely.
turns out the ve bus was connected to the wrong port. I connected it to the ve bus instead of the network connection port and it works correctly now.
Related topics
| Topic | Replies | Views | Activity | |
| Multiplus-II inverter not switching On with VE.Bus cable to Cerbo GX Connected | 27 | 974 | 13 January 2026 | |
| Multiplus2 will not turn on when connected to ve bus on cerbo | 5 | 843 | 23 April 2025 | |
| Cerbo GX not connecting to Multiplus-ii | 7 | 1178 | 26 March 2025 | |
| Cerbo GX MK2 - Will not turn Inverter back on | 40 | 614 | 13 January 2026 | |
| Multiplus 2 shutting down when connected to cerbo gx mk2 | 7 | 285 | 2 August 2025 |
