Inverter group not charging batteries
HELP: I have a travel trailer with two MultiPlus 3000 in split phase. I am on 50A service and there is no charging of the batteries. What could be wrong?
I have been Boondocking a lot, but it has been over a month since I had a generator hooked to the system. A few weeks ago, I opened up the compartment the whole system is in, and something went wrong—I’m not sure what—the Smart Battery Protect was not shutting off. I pulled the data input, and it started behaving correctly.
I know power is coming in because the Hughes 50 Amp Voltage Booster with Surge Protection is showing all green lights.
I do have access to VE Connect software, is there anything in there I should be looking at?
I would like to resolve this because I am only on 50 amps for about 12 hours and would like to top off my batteries.
I got into VE Configure 3 and both MultiPlus 3000 are configured this way with the exception that Ground relay is unchecked on L2
TAB: General
System frequency 60Hz
Shore current 50.0 A
Overruled by remote checked
Dynamic current limiter unchecked
TAB: Grid
Country / grid code standard None: (feeding energy from DC to grid not allowed)
Accept wide input frequency range (45-65 Hz) checked
AC low switch mains off 90 V
AC low switch mains on 97 V
AC high switch mains on 135 V
AC high switch mains off 140 V
UPS function unchecked
TAB: Inverter
PowerAssist checked
Assist current boost factor 2.0
Inverter output voltage 120 V
Ground relay checked
Inverter DC shut-down voltage 12.00 V
Inverter DC restart voltage 12.50 V
Low DC alarm level 12.50 V
Do not restart after short-circuit (VDE 2510-2 safety) unchecked
enable AES unchecked
TAB: Charger
Enable charger checked
Weak AC input unchecked
Stop after excessive bulk unchecked
Lithium batteries checked
Disable VSense (for diagnostic purposes) unchecked
Configured for VE.Bus BMS unchecked
Charge curve Fixed
Absorption voltage 14.20 V
Float voltage 13.50 V
Charge current 120 A
Repeated absorption time 1.00 Hr
Repeated absorption interval 7.00 Days
Absorption time 1 Hr
TAB: Virtual switch
TAB: Usage
Virtual switch usage Do not use VS
TAB: Assistants
TAB: Assistant Configuration
Assistants not used
TAB: Advanced
limit internal charger to prioritize other energy sources unchecked
