After receiving a suggestion from a member, that was later deleted, to look at a condition statement, I followed a more detailed approach to diverting excess solar energy once my batteries got to either Absorption or Float state. These batteries are VRLA and their charging voltage under either of the two mentioned states varies by battery temperature. (Battery temperature adjustment is not applicable for lithium batteries).
A timer is added for evaluating the algorithm, presently set at 2 seconds. A Solid State Relay is able to handle these changes, whereas a Contactor with electromagnetic properties can suffer from contact degradation.
The purpose was to minimise draw from the batteries and as a consequence will extent battery life.
I am only part way through learning Javascript, so in essence a novice beginner, but in spite of myself I managed to get this Function node to work.
I will need to monitor the heat dissipation of the SRR with a temperature data logger but I do not expect an issue. Certainly the 25A SSR on my 3 group coffee boiler which cycles at 135 cycles per minute under the PID controller did not show heat dissipation issues.
"id": "09f193279e87f963",
"type": "tab",
"label": "Absorption Relay Trigger",
"disabled": false,
"info": "",
"env": []
"id": "efd24cb7f2dcf7de",
"type": "victron-input-solarcharger",
"z": "09f193279e87f963",
"service": "com.victronenergy.solarcharger/288",
"path": "/State",
"serviceObj": {
"name": "Solar Trina Panel",
"communityTag": "solarcharger"
"pathObj": {
"path": "/State",
"type": "enum",
"name": "Charge state",
"enum": {
"0": "Off",
"2": "Fault",
"3": "Bulk",
"4": "Absorption",
"5": "Float",
"6": "Storage",
"7": "Equalize",
"245": "Off",
"247": "Equalize",
"252": "External Control"
"name": "TR C/State",
"onlyChanges": false,
"roundValues": "no",
"rateLimit": "2",
"outputs": 1,
"conditionalMode": false,
"outputTrue": "true",
"outputFalse": "false",
"debounce": "2000",
"x": 80,
"y": 40,
"wires": [
"3aa4465902983b86"
"id": "54c771e5b3a741de",
"type": "victron-output-relay",
"service": "com.victronenergy.system/0",
"path": "/Relay/1/State",
"serviceObj": {
"name": "Venus device"
"pathObj": {
"type": "enum",
"name": "Venus relay 2 state",
"enum": {
"0": "Open",
"1": "Closed"
"mode": "both"
"initial": 0,
"name": "GX Relay2",
"rateLimit": 0,
"outputs": 0,
"condition1Operator": ">",
"condition2Enabled": false,
"condition2Service": "",
"condition2Path": "",
"condition2Operator": ">",
"logicOperator": "AND",
"outputOnChange": false,
"debounce": 2000,
"x": 730,
"y": 380,
"wires": []
"id": "4d2ad28c3b4486d4",
"type": "debug",
"name": "AbsVoltTemp debug",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 620,
"y": 180,
"wires": []
"id": "3fc571a974b7f7c7",
"type": "victron-input-battery",
"service": "com.victronenergy.battery/279",
"path": "/Dc/0/Temperature",
"serviceObj": {
"name": "Shunt Yuasa 533ah",
"communityTag": "battery"
"pathObj": {
"type": "float",
"name": "Battery temperature (°C)"
"name": "Shunt Temp",
"rateLimit": "2",
"outputs": 1,
"debounce": "2000",
"x": 90,
"y": 220,
"wires": [
"d70b09f208325fe6",
"55e013630bfba5e2"
"id": "55e013630bfba5e2",
"type": "change",
"name": " Absorption Voltage Temp Adj.",
"rules": [
"t": "change",
"p": "payload",
"pt": "msg",
"from": "35",
"fromt": "num",
"to": "56.952",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "34",
"fromt": "num",
"to": "57.0168",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "33",
"fromt": "num",
"to": "57.0816",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "32",
"fromt": "num",
"to": "57.1464",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "31",
"fromt": "num",
"to": "57.2112",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "30",
"fromt": "num",
"to": "57.276",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "29",
"fromt": "num",
"to": "57.3408",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "28",
"fromt": "num",
"to": "57.4056",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "27",
"fromt": "num",
"to": "57.4704",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "26",
"fromt": "num",
"to": "57.5352",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "25",
"fromt": "num",
"to": "57.6",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "24",
"fromt": "num",
"to": "57.6648",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "23",
"fromt": "num",
"to": "57.7296",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "22",
"fromt": "num",
"to": "57.7944",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "21",
"fromt": "num",
"to": "57.8592",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "20",
"fromt": "num",
"to": "57.924",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "19",
"fromt": "num",
"to": "57.9888",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "18",
"fromt": "num",
"to": "58.0536",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "17",
"fromt": "num",
"to": "58.1184",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "16",
"fromt": "num",
"to": "58.1832",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "15",
"fromt": "num",
"to": "58.248",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "14",
"fromt": "num",
"to": "58.3128",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "13",
"fromt": "num",
"to": "58.3776",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "12",
"fromt": "num",
"to": "58.4424",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "11",
"fromt": "num",
"to": "58.5072",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "10",
"fromt": "num",
"to": "58.572",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "9",
"fromt": "num",
"to": "58.6368",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "8",
"fromt": "num",
"to": "58.7016",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "7",
"fromt": "num",
"to": "58.7664",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "6",
"fromt": "num",
"to": "58.8312",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "5",
"fromt": "num",
"to": "58.896",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "4",
"fromt": "num",
"to": "58.9608",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "3",
"fromt": "num",
"to": "59.0256",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "2",
"fromt": "num",
"to": "59.0904",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "1",
"fromt": "num",
"to": "59.1552",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "0",
"fromt": "num",
"to": "59.22",
"tot": "num"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 350,
"y": 160,
"wires": [
"4d2ad28c3b4486d4",
"77507bf9233a26cf"
"id": "c75b1c5af0d8310e",
"type": "function",
"name": "4 input condition Function",
"func": "'use Strict';\nlet state = flow.get('state') || 0;\nlet voltage = flow.get('voltage') || 0;\nlet abstempvolt = flow.get('abstempvolt') || 0;\nlet floattempvolt = flow.get('floattempvolt') || 0;\nlet controla = voltage - (abstempvolt - 0.2);\nlet controlb = voltage - (floattempvolt - 0.2); \n \nif (state === 4 && controla > 0) {\n msg.payload = 1;\n} \nelse\nif (state === 5 && controlb > 0) {\n msg.payload = 1;\n}\nelse {\n msg.payload = 0;\n}\n\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 490,
"y": 380,
"wires": [
"7feaad870781d4f9",
"54c771e5b3a741de"
"id": "d70b09f208325fe6",
"type": "change",
"name": "Float Voltage Temp Adjustment",
"rules": [
"t": "change",
"p": "payload",
"pt": "msg",
"from": "35",
"fromt": "num",
"to": "54.522",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "34",
"fromt": "num",
"to": "54.6168",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "33",
"fromt": "num",
"to": "54.6816",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "32",
"fromt": "num",
"to": "54.7464",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "31",
"fromt": "num",
"to": "54.8112",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "30",
"fromt": "num",
"to": "54.876",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "29",
"fromt": "num",
"to": "54.9408",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "28",
"fromt": "num",
"to": "55.0056",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "27",
"fromt": "num",
"to": "55.0704",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "26",
"fromt": "num",
"to": "55.1352",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "25",
"fromt": "num",
"to": "55.2",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "24",
"fromt": "num",
"to": "55.2648",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "23",
"fromt": "num",
"to": "55.3296",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "22",
"fromt": "num",
"to": "55.3944",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "21",
"fromt": "num",
"to": "55.4592",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "20",
"fromt": "num",
"to": "55.524",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "19",
"fromt": "num",
"to": "55.5888",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "18",
"fromt": "num",
"to": "55.6536",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "17",
"fromt": "num",
"to": "55.7184",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "16",
"fromt": "num",
"to": "55.7832",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "15",
"fromt": "num",
"to": "55.848",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "14",
"fromt": "num",
"to": "55.9128",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "13",
"fromt": "num",
"to": "55.9776",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "12",
"fromt": "num",
"to": "56.0424",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "11",
"fromt": "num",
"to": "56.1072",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "10",
"fromt": "num",
"to": "56.172",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "9",
"fromt": "num",
"to": "56.2368",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "8",
"fromt": "num",
"to": "56.3016",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "7",
"fromt": "num",
"to": "56.3664",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "6",
"fromt": "num",
"to": "56.4312",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "5",
"fromt": "num",
"to": "56.496",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "4",
"fromt": "num",
"to": "56.5608",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "3",
"fromt": "num",
"to": "56.6256",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "2",
"fromt": "num",
"to": "56.6904",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "1",
"fromt": "num",
"to": "56.7552",
"tot": "num"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "0",
"fromt": "num",
"to": "56.82",
"tot": "num"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 350,
"y": 280,
"wires": [
"23db4689d782af3b",
"f79a71a1d299254b"
"id": "23db4689d782af3b",
"type": "debug",
"name": "FloatVoltAdj debug",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 610,
"y": 300,
"wires": []
"id": "7feaad870781d4f9",
"type": "debug",
"name": "debug 5",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 760,
"y": 460,
"wires": []
"id": "bf5ed7c5332d9077",
"path": "/Dc/0/Voltage",
"serviceObj": {
"pathObj": {
"type": "float",
"name": "Battery voltage (V)"
"name": "Shunt Volts",
"roundValues": "2",
"rateLimit": "2",
"outputs": 1,
"debounce": "2000",
"x": 90,
"y": 100,
"wires": [
"06c01ca8695077a8"
"id": "3aa4465902983b86",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "state",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 270,
"y": 40,
"wires": [
"id": "06c01ca8695077a8",
"type": "change",
"name": "set flow.voltage",
"rules": [
"t": "set",
"p": "voltage",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 280,
"y": 100,
"wires": [
"id": "77507bf9233a26cf",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "abstempvolt",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 620,
"y": 140,
"wires": [
"id": "f79a71a1d299254b",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "floattempvolt",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 620,
"y": 260,
"wires": [
"id": "54826942e1266cfb",
"type": "inject",
"name": "Timer set to seconds (2)",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "2",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 230,
"y": 380,
"wires": [
"c75b1c5af0d8310e"
"id": "76cbb305dfa7ee68",
"type": "victron-virtual",
"name": "Davis Vantage Pro 2",
"outputs": 1,
"device": "meteo",
"default_values": true,
"acload_nrofphases": 1,
"enable_s2support": false,
"battery_capacity": 25,
"include_battery_temperature": false,
"battery_voltage_preset": "24",
"battery_voltage_custom": 24,
"generator_type": "ac",
"generator_nrofphases": 1,
"include_engine_hours": false,
"include_starter_voltage": false,
"include_history_energy": false,
"grid_nrofphases": 1,
"include_motor_temp": false,
"include_controller_temp": false,
"include_coolant_temp": false,
"include_motor_rpm": true,
"include_motor_direction": true,
"position": 0,
"pvinverter_nrofphases": 1,
"switch_1_type": 1,
"switch_1_min": 0,
"switch_1_max": "",
"switch_1_initial": 0,
"switch_1_label": "",
"switch_1_unit": "",
"switch_1_step": 1,
"switch_1_customname": "",
"switch_1_group": "",
"switch_1_include_measurement": false,
"switch_1_rgb_color_wheel": false,
"switch_1_cct_wheel": false,
"switch_1_rgb_white_dimmer": false,
"fluid_type": 0,
"include_tank_battery": false,
"include_tank_temperature": false,
"tank_battery_voltage": 3.3,
"tank_capacity": 0.2,
"temperature_type": 2,
"include_humidity": false,
"include_pressure": false,
"include_temp_battery": false,
"temp_battery_voltage": 3.3,
"x": 160,
"y": 480,
"wires": [
"id": "7d2bfbbfb33a986c",
"type": "global-config",
"env": [],
"modules": {
"@victronenergy/node-red-contrib-victron": "1.6.63"
Dashboard view of Relay and other data.pdf (314.6 KB)
I have attached a dashboard screenshot, the flow and the function node script.
Thank you to all who replied
