Informations about Converter 24->12 30A
I’m looking for a 24-volt to 12-volt converter.
The most powerful one I’ve found is the 30A model, but I see it’s an older model that doesn’t have Bluetooth connectivity and can’t be monitored but this old version doesnt have BT.
Does Victron offer a newer, more powerful model?
Thank you :blush:
Orion XS is the newest most capable model that provides advanced connectivity and can work both as a DC-DC converter and also as a battery charger. For your setup, you will need the “XS 1400” model, it can output 50A @12V.
The highest amperage model is the older Orion 24/12-70, albeit with no connectivity whatsoever.
Thank you very much for your reply.
I’ve already bought an XS1400 so I can charge my 24V battery with the 12V from my alternator.
I didn’t know this device had a dual function; so I’ll have to buy a second one
One will serve as a charger and the other as an inverter.
