How to read BMS/Multiplus values using API, ModbusTCP or MQTT
I use VRM API, ModbusTCP and MQTT.
I would like to read:
  • Multiplus settings, such as Absorption voltage or Float voltage
  • Battery/BMS statistical values, such as min/max cell voltage (which is available in the VRM as a Widget)
Regarding Multiplus settings; I want to read the values remotely (no MK3 cable) to investigate a system whether settings are correct and/or inadvertently changed. This would save a site-visit.
Regarding Battery/BMS, I can get the battery voltage and SOC, using the VRM-API/stats with attributes bv and bs, but I cannot find the correct attributes for min/max cell voltage. The closest I find (VRM-API/attributes) are 173/mcV for Minimum cell voltage and 174/McV for Maximum cell voltage, but the VRM stats-API does not return information.
Suggestions more than welcome!
These are mostly all available from the GX via MQTT.
Go download the modbus register from the victron git page, just google it.
Nodered is also a preferred way of doing this - refer to the dedicated nodered section in this forum.
The multiplus basic settings and assistants are typically only configurable via a mk3 or remote veconfigure.
Yes, I did find the register (CCGX-Modbus-TCP-register-list-3.71.xlsx) but did not find the Absorption/float values.
Using MQ Explorer I did not find those settings either.
If you know the register values, please let me know.
I don’t believe the internal settings can be accessed like that.
Thanks
