Yes, but that is Not the Problem. The problem is Not that I can‘t read the State of the second (B).
For now, I only want to read the state of A (0x08). That work only If I have A connectet alone. If I have A and B connected it fails.
Good News, with two 10k pullup resistors between the gpios and Vbus it works
Now I have to rewrite the code to read both, A and B
Updated version for 2 distributor with DIP Switches set to A and B:
#https://www.wemos.cc/en/latest/s2/s2_mini.html
#https://github.com/twam/dbus-lynx-distributor
#https://community.victronenergy.com/t/how-to-power-the-lynx-distributor-and-read-the-fuse-states-with-esphome/3534
#rj10
# pin 1 yellow = VBUS
# pin 2 green = SDA = GPIO33
# pin 3 red = SCL = GPIO35
# pin 4 black = GND
esphome:
comment: Victron distributor status
esp32:
board: lolin_s2_mini
variant: ESP32S2
framework:
type: esp-idf
logger:
level: INFO
hardware_uart: USB_CDC
debug:
update_interval: 120s
api:
ota:
platform: esphome
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_password
output_power: 12 #Formerly: 8.5
ap:
ssid: Lynxfallback
captive_portal:
light:
- platform: status_led
icon: "mdi:alarm-light"
restore_mode: ALWAYS_OFF
pin:
number: GPIO15
inverted: false
i2c:
- id: bus_a
sda: GPIO33
scl: GPIO35
frequency: 50kHz
scan: true
#i2c_device:
# id: lynx_a
# address: 0x08
# #Lynx A = 0x08
# #Lynx B = 0x09
# #Lynx C = 0x10
# #Lynx D = 0x11
time:
- platform: homeassistant
on_time:
seconds: /30
then:
- lambda: |-
uint8_t data;
esphome::i2c::I2CDevice dev;
dev.set_i2c_bus(bus_a);
dev.set_i2c_address(0x08);
auto err = dev.read(&data, 1);
if (err == esphome::i2c::ERROR_OK) {
ESP_LOGI("lynx", "Read %x=%x", 0x08, data);
id(lynx_a_busbar_no_supply).publish_state((data & 0x02) != 0);
id(lynx_a_fuse_1_broken).publish_state((data & 0x10) != 0);
id(lynx_a_fuse_2_broken).publish_state((data & 0x20) != 0);
id(lynx_a_fuse_3_broken).publish_state((data & 0x40) != 0);
id(lynx_a_fuse_4_broken).publish_state((data & 0x80) != 0);
} else
ESP_LOGE("lynx", "Read failed");
on_time:
seconds: /30
then:
- lambda: |-
uint8_t data;
dev.set_i2c_address(0x09);
ESP_LOGI("lynx", "Read %x=%x", 0x09, data);
id(lynx_b_busbar_no_supply).publish_state((data & 0x02) != 0);
id(lynx_b_fuse_1_broken).publish_state((data & 0x10) != 0);
id(lynx_b_fuse_2_broken).publish_state((data & 0x20) != 0);
id(lynx_b_fuse_3_broken).publish_state((data & 0x40) != 0);
id(lynx_b_fuse_4_broken).publish_state((data & 0x80) != 0);
} else
binary_sensor:
- platform: template
name: "lynx A busbar no supply"
icon: mdi:flash-alert
name: "lynx A fuse 1 broken"
icon: mdi:fuse-alert
name: "lynx A fuse 2 broken"
name: "lynx A fuse 3 broken"
name: "lynx A fuse 4 broken"
name: "lynx B busbar no supply"
name: "lynx B fuse 1 broken"
name: "lynx B fuse 2 broken"
name: "lynx B fuse 3 broken"
name: "lynx B fuse 4 broken"
- platform: gpio
pin:
number: GPIO0
inverted: true
mode:
input: true
pullup: true
filters:
- delayed_on_off: 100ms
name: "lynx button 0"
on_click:
- logger.log: "Button 0 pressed"
- light.turn_on: lynx_status_led
- delay: 100ms
- light.turn_off: lynx_status_led
sensor:
- platform: wifi_signal
name: "lynx Wi-Fi Signal"
- platform: internal_temperature
update_interval: 300s
- platform: uptime
type: seconds
text_sensor:
- platform: version
name: "lynx ESPHome Version"
hide_timestamp: true
- platform: debug
device:
name: "lynx Device Info"
reset_reason:
name: "lynx Reset Reason"
