How to configure Cerbo GX for Octopus flux
Is there a simple set of COMPLETE instructions to configure my CerboGX and Quattro 10 KW inverters to charge overnight between 2 and 5 (that bit Ive Done) but then export at the maximum between 4pm and 7pm in the evening. This is the bit that doesn’t appear to work.
You could turn on DESS, there is a manual here Dynamic ESS Manual [Victron Energy]
After you have setup your prices it will automatically charge and discharge when it is best. Be aware it does disable schedule charging
Beyond that as you have fixed times and prices it can be don with a scheduled charge and node red to force export. Come back if you want to know how to set that up as it is fairly easy.
Dave
Doesn’t appear to work. My overnight charging is OK but outside the cheap hours the system won’t export. Ive set up a schedule
You might well have setup a charge schedule, but from what youve shown all you’ve
done is setup the amount of feed in … along with an odd inverter limitation.
Have a really good read of the DESS manual.
Thanks.
I advise on solar batteries etc but Victron lag behind the competition such as Ecoflow. They have many (including Octopus) pre configured settings for energy saving. I have been in touch with many distributors and installers, paid for their time but they cant figure it out either. The manual is awful (I wrote manuals for ERP systems) and should have some sample setups.
Is it beyond Victron ability to just say if you want to export above a min SOC here’s sample settings.
Having said that I and happy with my setup, not with the after sales support which at this stage prevents me for recommending Victron.
I installed in 2021 but have an up to date Cerbo GX.
There are at least 2 different ways of achieving what you want
  1. Use the charging schedules you are already using to charge batteries and then install node red to schedule discharging by forcing the grid setpoint negative
There is a slightly old but still useful video series on this here https://youtu.be/i_iaciqn_Fg?si=b6VDc_BEpmkxdyw7
  1. Setup DESS (as I said Before) This is not done on the remote console but in the VRM webpage from setting
goto the dess setting
Edit each of the sections
Under the buy/sell prices
There is an option to select Dynamic and enter you Octopus account details along with a video as to where to get these off the octopus webpage.
As you are on flux it would also be possible to simply add you buy and sell prices on the fixed schedule option. They are two tabs one for buy and one for sell.
As a tip if using the fixed scheduler you can “force” the system the charge and discharge during those times by setting a very low 0p price during your offpeak inport times and a very high price 99p during your peak export time.
Once setup your VRM dashboard should show your prices with the expected export import
Here you can see mine for today it automatically lowered the import overnight because agile export prices are very low today due to the storm but I have scheduled two of my free hours for today and it is importing then to export when prices rise during the evening.
The system is very powerful and learns your usage/solar etc but you are able to adjust the forecasts
Two of my friends have adopted the ecoflow ecosystem and both of them wish they had the configurability and flexibility that my Victon system provides.
As I said before this will turn off your scheduled chargers.
Once setup if you want to turn it off you do this from the controls menu in VRM which appears when you turn on real time updates
Hopefully this helps. If not come back and I can guide you through it
Dave
Thanks for that.
One small thing was stopping me getting started. The config does not work in Safari; as soon as I used chrome it became straight forward
