How to configure Cerbo GX as LAN gateway for Siemens LOGO (Starlink WiFi as WAN)
Hi all,
I’m trying to use my Cerbo GX (v3.66, new GUI) as a small LAN gateway for my Siemens LOGO PLC.
  • My Starlink router has no LAN port (only WiFi).
  • The Cerbo is connected as a WiFi client to Starlink (so the Cerbo itself has internet).
  • I would like to use the Cerbo LAN port to create a local subnet (192.168.250.xxx) where my Siemens LOGO and a laptop can get DHCP addresses.
  • I read that in previous Cerbo GX firmware there was a setting Ethernet Function → LAN (hosted), but in the new GUI I can’t find it.
  • In the current menus (GUI v2) I only see “IP config: Automatic / Manual”.
:backhand_index_pointing_right: My goal:
Cerbo stays online via Starlink WiFi (WAN), and at the same time the LOGO PLC gets an IP from the Cerbo on the LAN port, so I can reach it locally.
Has anyone already done this on v3.66?
Thanks!
The Cerbo (intentionally) does not offer any router functions.
Use a tiny router like Gl.int for that
A router function or even multiple IP levels do not work with the GX . Maybe the little OctoGX has this Feature … :thinking:
Why do you want or need to access the Siemens LOGO via the Internet?
To adjust the programming. But it can be down directly too. So not a real big deal.
The Cerbo is a linux computer
The command “route add” is available
Thanks Fredd, can you give some extra info please.
Have ssh access? and have Linux experience (command line)?
Simple example
https://devconnected.com/how-to-add-route-on-linux/
Of cause you can do so. But the functions works not out of the box without any manual modifications.
there is a way with tailscale
