How many panels with Easysolar II
What is the max number of panels that can be connected to Easysolar II GX 24/3000/70-32 250-70 in series or parallel?
From spec power rating of Easysolar is max 2000W and solar controller is max 250V or 70A. Below is spec for solar panel. Im not sure if you can connect max 7 panels (or 6 panels or 4 panels) in parallel or 5 panels (or 4 panels) in series?
Panels spec (450W):
Maksimum power voltage Vmpp (V) 44.6
Maksimum power current Impp (A) 10.09
Open circuit voltage Voc (V) 52.9
Open circuit current Isc (A) 10.74
Module efficiency 22.5
at irrdiance 1000 W/m2, cell temperature 25 0C, air mass AM 1.5
First step is using MPPT Calculator - Victron Energy
That is not correct calculator. There is no Easysolar II GX in the menu.
I bought this product and need help.
Hi. This isn’t a support site it is a community. Your supplier is there to support you.
If you read the datasheets for the easy solar GX, which is a combined inverter and mppt, you will see that depending on the model it contains.either a 250/70 or 250/100 MPPT, which are definitely in the calculator.
You just need to read the docs.
Getting upset with a community that volunteers to help isn’t the way to attract help.
You will find the model number of the mppt in the EasySolar manual.
Plug your panel’s figures into the calculator.
There are advanced options there you can select Inverter and AC Charger (and the system voltage)
That way it should only show the 24V EasySolar models.
