Easy solar 2 gx. PV max input load
Hello.
I have an easy solar 2 gx. I live in central portugal. I have purchased 4 x 550 watt panels however the max rated input is 2000w…
Can anyone advise aa to if there is a tolerance of an extra 10% as it is unlikely the panels will be always producling the max rated output.
Thanks
No problem at all, as long as you respect the max voltage when connected in series and or parallel
