Ottmar
(Ottmar Konrad)
25 May 2026 10:34
1
Hi all,
i search for a way to switch in-between the modes -Optimized with batteryLife, optimized without batteryLife and keep batteries charged- as VRM Controls does. However, while searching through all the Node-Red nodes, I did not find such an option.
Any ideas or other approaches to achieve this?
Thanks Ottmar
Find the Victron pallette - ESS control node and select venus gx- measure ment is ess state. It is there
Ottmar
(Ottmar Konrad)
25 May 2026 16:14
3
thanks for your fast response, but unfortunately thats not possible there. (see attachment)
Note: Using GX-Firmware V. 3.73 and Victron Nodes V. 1.6.64 (latest, non-Beta)
Other Ideas?
nickdb
(Nick)
25 May 2026 17:05
4
It is in an ess or system control node. Just search in this forum. Discussed many times before.
Ottmar
(Ottmar Konrad)
25 May 2026 17:26
5
Thanks Nick,
appreciate your answer, but i can promise, thats my first effort before i post a new topic here. As i mentioned above, i have searched through all senseful nodes including Custom Control, VRM API etc. but found nothing. Maybe i have overlooked somthing, that’s why i post it here.
Not ess.mode use ess state …for the measurement.
Ottmar
(Ottmar Konrad)
25 May 2026 17:40
7
Thanks again LX,
but ESS State is “only” readable and not an option to control. Do you use an other version? Beta?
I will update my GX to 3.73 and find out if maybe it has moved. And let you know.
I have been switching states for ages now using this method.
Ottmar
(Ottmar Konrad)
25 May 2026 17:51
9
Hi LX,
thanks so much for your help and effort. You can be sure, that i have searched in all directions, because i doubted in myself.
Attached the screenshot of the ESS/Venus Control Node Options.
It isn’t there after the update i couldn’t find it either and the flow I have does not work. I am uo to date on 3.73 normal release
But here is a discussion from the beta side.
Hi, I’m running venus OS 3.70~88 and still do not have the “ESS state” in the ESS output node.
But I found another way to edit this setting from node red, you have to directly act on the dbus: dbus · victronenergy/venus Wiki · GitHub
I use the “custom control“ node: for custom I select “com.victronenergy.settings“ and measurement I select “/Settings/CGwacs/BatteryLife/State“
[image]
[image]
Lol. It has moved. So you aren’t blind or mad.
It seems the only way to do it right now it with a custom node. So i have changed my flow to suit.
Ottmar
(Ottmar Konrad)
25 May 2026 18:17
12
Hi Nick,
looks strange, what versions do you use (GX, Victron-Nodes, etc.)
@lxonline : Thanks, i give that a try and let you know
nickdb
(Nick)
25 May 2026 18:36
13
Previous beta. Some errors were fixed
Ottmar
(Ottmar Konrad)
25 May 2026 18:40
14
Hi back and satisfied,
Thank you guys especially to LX, that is working me.
Looks like a temporary version problem.
Have a nice evening
Ottmar
