Feature to add: Self consumption setting from battery to Node-Red
Hello, would be really nice to have possibility to control Self consumption from battery in ESS in Node-RED.
For example I would like to create Flow with this setting to automatically change to Critical loads only for winter season according date or PV yield forecast.
Would be really helpful! Have a nice day!
Martin
Me too, need to switch between CL & All, hopefully it will be on next firmware update
Hello, is there any progress? Now I would use this feature also for switching it on criticals only when EV is in charging mode on EVCS. Because when I switch to MANUAL mode and have all loads setting and there is not sufficient PV yield, its automatically drains my battery to the EV which I do not want instead of charging from grid.
