Hello! I have been trying to hide the trackers that are not in use. I thought it was done from victron connect but it doesn’t seem to change anything. Would be awesome to find a way yo hide them.
I would try to reboot the GX device.
i tried.. did not work.
Maybe that OFF has something to do with it?
Meaning, when OFF, there is no update to the VRM info…
And I will kindly ask you something…
Make a little test and turn off the visibility of a producing MPPT, for example, Solar 2 - Solar Norte.
When the visibility is turned off, is the MPPT still producing?
Thanks in advance. ![]()
Hi @crewdragon
You need the upcoming venus firmware version 3.60 for this to work on VRM.
With kind regards,
Thiemo van Engelen
