Morning/afternoon all depending on time zones.
Right i have a head scatcher i cant seem to work out. I’ve attached a photo of the system
In brief, battery only system, currently no PV so ignore that side of the image, this was only for G99 approval
Wanting to run ESS through cerbo GX device but i cant get Victron to supply the demand created by the main consumer unit. EM112 is in the main CU and is connector to GX and working, i also have a CT clamp connected as external to Victron on the 25mm tail after the DNO import energy meter
both of which are recognised in main dashboard, CT clamp shows as essential loads and EM112 shows as AC loads.
The sub consumer unit is fed direct in 25mm tails does not go through the main consumer unit. ideally i want the main consumer unit to be fed back from AC IN (single leg mode) and i have another consumer unit downstream i want to connect on AC2 out,
Am i doing something wrong or how its wired isn’t possible as it doesn’t go through the main CU
from my thinking it shouldn’t matter so is it how ive go the energy meter set in remote console or where i’ve placed the CT.
hyperlink to PDF
https://acrobat.adobe.com/id/urn:aaid:sc:EU:8e9caaf4-69e5-4bfa-8fb1-c1b264d00774
thanks in advance.
