GX Touch 50/70 Display for Cerbo GX - cable extension
Is it possible to extend the 6’ cable coming out of the display? The display cable is somewhat special in that it has a split HDMI and USB connection. Can I just plug in an HDMI cable extender into the HDMI cable and USB cable extender in to the USB connector and run them both to the Cerbo GX? I want to lengthen the distance between the display and Cerbo GX to about 15 feet. Thanks!
We already had that topic here and in the old community.
Officially no.
But it is possible.
Extending HDMI is easy I already did that over 10 meters.
USB is the power supply and extending that will cause a voltage drop that can cause problems.
I use small PCB with a 12V and a USB output for that.
e.g. DEBO DC 2XUSB: Entwicklerboards - Spannungsregler 6...40 V DC auf 2x USB 5V - 3A, bei reichelt elektronik
+1 on that request. I want to put the cerbo gx in a travel trailer and mount the display in the middle of the trailer. Probably need to extend to 20 feet. I would happily mount a small usb power supply and use the Touch’s cable to power the display.
Does anyone know what HDMI extenders work? Please share! I am surprised that Victron doesn’t get this request more often!
Thanks!
Matthias already answered this. I will add that the Touch 70 is far more sensitive to HDMI extension cables, while the Touch 50 generally has no issues. Like Matthias, we’ve extended HDMI cables 10 meters without issue when using the Touch 50. We also use USB extension cables without issue. Both cables should be high quality and use “large” conductors to reduce voltage drop. Don’t buy thin cables because that means very thin conductors.
Hi everyone,
I just installed a 5m extension between my Cerbo GX and the GX touch 50. It works without any problems, picture as well as touch functionality are flawless.
I ordered some random stuff at Amazon, not the most basic ones but sure not high-end either (17€ for the HDMI extension and 12€ for the USB.)
Hope that helps and best regards, Jochen
We have used extensions to 10meters.
Has there been any news on Extending the HDMI and USB i have tried 6 extenders from amazon and none of them worked so I tried a Crestron one ($800 USD) as we are a dealer to try it and the image comes up find but no control and i have tried rebooting everything in all possible orders
this seems like a big design flaw on otherwise amazing equipment
  1. It’s not officially supported to extend the HDMI cable.
  2. I already did it without problems with normal 10-15€ cables. The cable just needs to be fully wired (high speed with ethernet) for the additional data communication.
Extending the USB is a bit more complicated.
If the cable is too long/thin it causes a voltage drop and the display backlight goes on and off.
I recommend to use an USB power supply to directly feed the USB without extension.
the HDMI connector is not standard on the Victron GX, the control signals for the touch interface are sent over HDMI connector on the GX touch which is not a standard, so the Crestron extenders and DM will not work with the touch function. The USB is for power only so that does not need to connect to the GX, just the HDMI with a physical extension cable, can’t use active balun or extenders.
If the extension is done improperly and the backlight doesn’t work appropriately, is the touch screen ruined?
