I have a problem with Gui Mod in VenusOS. I installed the beta version on the raspberry Pi but GuiMod says that it cannot be installed. Please help.
You posted an image with the error text in the post before…
Where is it?
Here, I found it on the webexplorer cache.
It’s possible that the GuiMods author ( @kwindrem ) to need some time to adapt it to the newest beta version.
I see on Github that he made adaptions up until 3.50~25
Hello. I have a problem with Gui Mod in VenusOS. I installed the beta version on the raspberry Pi but GuiMod says that it cannot be installed. Please help.
Yes, this is known. Victron made subtantial changes to the generator interface a few beta versions back and the changes to my code to support them is substantial. In addition my time right now is focused on moving to a new home.
I’ll get to it eventually but for now you would need to revert to a previous beta or the released code to run GuiMods.
ok, I understand that GuiMods are no longer updated, but on an LCD attached to Raspberry Pi 4, what settings do I need to make to display the Gui-v2 interface and not the GuiMods interface? I mention that in the area: Settings-Display & Language, Gui-v2 does not appear. The last menu is the Units menu. I tried with Firmware 3.50~9 and 3.50~31
As with some beta problems roll back doesn’t solve all due to under the hood changes. Beta means there is a likelihood that it is not working properly.
You may have to factory reset and fresh install a normal release, then go back up to beta again.
