per title, updated to fresh 3.62, all modifications are disabled and system shows ‘unmodified’, but GUI v2 is stuck at loading screen (from local.venus). Can revert to original GUI from VRM and new GUi is working from there, but would like to get new GUI to work on the local network.
I had this and it was either bad wifi connection or needed rebooting. I went to the shed to move it slightly and rebooted it at the same time. Seems to be working ok. Check what you ping times are to the Pi
Powered on after 12 hours of being off and it didn’t resolve it. Starlink is less than 10ft away and nothing else is using the connection.
Weird, well i hope you get it sorted as it is a pain
Did you try another device to access the console?
Clear the browser cache.
yes, tried from iPhone and laptop (multiple browsers).
did factory reset per 19. Reset to factory defaults and Venus OS reinstall
reinstalled to firmware 3.62 from beta 3.70~5 and ~6, still getting over 2 minutes of loading every time that v2 page is refresh in phone’s browser.
@mpvader @M_Lange anything else I should try or do? v1 works instantly and is very responsive
Hey @sdfasd21
Thank you for all feedback & experimenting!
What is the wifi signal strength reported in the GX it self?
63%
As a test plugged in ethernet cable - same issue, so its not due to wifi
