Gui mods don't work anymore
As of this date the gui mods for RaspberryPi do not work for Remote Console.
I miss seeing the output of the two scc’s I have in the Remote Console while watching the AC loads and battery and Grid input icons. Don’t want to switch back and forth.
That said, it would be best to see both the scc in Remote Console in the Overview screen.
Did you update Venus OS to 3.50?
GUI mods doesn’t support the new GUI V2.
https://communityarchive.victronenergy.com/questions/244320/guimods-will-not-be-available-in-gui-v2.html
I changed Venus OS back to version 3.42 and that solved the problem. The automatic update setting has now been disabled.
If you activated automatic updates than this could be the case.
Automatic updates are disabled by default.
If you don’t like it you can go back to the previous version 3.42 and disable the updates.
Correct- see above.
