I have tried now a couple of times with the new beta gui2 to the latest updates but when I try to connect remotely through the Cerbo gx the remote console is missing. The only way I can do it is by using my ip address but that’s if I are on the same network. Before I could Connect if away from home and just wanted to check on things is there a setting that I are missing. Thanks Pat
Up until recently if you had Gui2 showing on the Cerbo, you could not use remote console on VRM as it was expecting Gui1 so there was a menu item Gui2 to show it. With one of the recent updates over the past few days VRM remote console now works with gui2.
Thank you ![]()
