At first my system setup: 3x multiplus II, Battery, Cerbo GX (Venus OS 3.53), EVCharger on ACIn ( Firmware EVCS_Main_FW_OTA_V02.01_C025.evcsup), EM540 on ACIn before EVCharger in order to exactly measure the EV consumption, No more ACin loads, GridMeter Kostal KSEM, …
My Problem: After adding EVCS without EM540 connection everything worked and was displayed correctly (EVCS on left ACIn side, correct Power ratings - but EVCS readings were a bit inaccurate). As soon as I activated additionally the EM540 readout via RS485 (on the AC supply to the EVCS) things got a little bit strange.
Ev Charger in Venus OS jumped to the right side. EV consumption is doubled as EM540 and EVCharger are summed up. Details:
VRM Error on left side: EVCharger states 14+ kW. Overall power balance seems good, EM540 current is taken into account:
EVCS Homescreen seems to be valid - mostly:
Venus OS gui V2 has an interesting interpretation about what’s going on
My detailed settings:
Question: Did I configure something wrong here? Can this be fixed through Venus OS settings?
Any help is highly appreciated!
Bg and tia,
MoJo
