Hi all
Since adding a second MP2 48/5000/70, running parallel with 80A grid connection and Victron CT clamp on main live, the VC Dashboard Grid info is showing around 71A when I draw just over 8kW for EV or battery charging.
When both the EV and battery are charging, my system maxes out at around the same level. The EV will get the full 7kW but the battery less than 1kW.
Minutes before I connected the CT during commissioning I drew 19kW. Around 8kW went to the battery and the rest to AC, which was strange as there was no big load running. (No EV connected)
Which possible setting errors should I check on VC or VEconfig?
Thanks for your suggestions.
