I set both grid current limit and peakshaving on at max. 25Amps. But still the grid current exceeds 25Amps. That is worrying. What goes wrong?
When I turn off DESS, the current limit decreases under 25Amps.
Also with DESS off and Keep Batteries Charged, the current limit is exceeded as well.
There is load on AC In and AC Out1. A VM-3 us used as grid meter
UPDATE: with this setting, it does not exceed
We experience the same, any solution yet?
See if it’s not due to the load current coming from the grid
to reduce the diffirence, I had reduced the charging current come from the grid
If it was related i dont know.
I stil had this going on with the latest Venus OS beta
Settings > System Setup > ESS > Peak shaving
Peak shaving ‘Always’
‘Limit system AS import Current’ switched off
‘Limit system AS export Current’ switched off
After switching both on en set the current to 26Amps on both options it works like a charme.
