Govee Temp sensors with ESP32
Hi…new here.
I installed Venus os on a Rpi4 with a touch display – that’s working great. Shunts, solar controllers, inverter…etc all working. Next step is to integrate Govee Temp sensors via ESP32 as a gateway. I found enough examples to get me as far as failure. I have dbus-mqtt-devices installed on Venus. My problem is that the EPS32 never connects to Venus (venus is on the same network: FBISurveillanceVan). This is the yaml file, that ChatGpt generated. Can anyone give me a clue how to get this working or how to debug it. ChatGpt also suggested additions to the services.yaml, but I’m not sure if that’s required?
I’ve read just about everything @freakent published, but there are just a few things I don’t understand in order to connect all the dots…
Any advice is welcome…thanks
Ron.
services yml
services:
  • name: LivingRoom
    type: temperature
    mqtt:
    temperature: govee/LivingRoom/temperature
    humidity: govee/LivingRoom/humidity
    battery: govee/LivingRoom/battery
  • name: Fridge
    type: temperature
    mqtt:
    temperature: govee/Fridge/temperature
    humidity: govee/Fridge/humidity
    battery: govee/Fridge/battery
  • name: Freezer
    type: temperature
    mqtt:
    temperature: govee/Freezer/temperature
    humidity: govee/Freezer/humidity
    battery: govee/Freezer/battery
govee-to-venus.yaml
esphome:
friendly_name: Govee to Venus
esp32:
board: esp32dev
framework:
type: esp-idf
logger:
level: DEBUG
ota:
wifi:
ssid: “FBISurveillanceVan”
password: “DEAD1DEAD1”
manual_ip:
static_ip: 192.168.1.253
gateway: 192.168.1.1
subnet: 255.255.255.0
mdns:
disabled: false
mqtt:
broker: 192.168.1.110
discovery: false
topic_prefix: govee
esp32_ble_tracker:
scan_parameters:
active: false
interval: 1100ms
window: 1100ms
LAMBDA DECODER (WORKS ON ALL ESPHOME VERSIONS)
Govee H5179 / H5111 / H5075 style packets:
Byte2-4 = temp/humidity encoded
Byte5 = battery
LIVING ROOM
on_ble_manufacturer_data:
  • mac_address: “AA:BB:CC:DD:EE:01”
    then:
    • lambda: |-
      if (x.size() < 6) return;
      int raw = (int(x[2]) << 16) | (int(x[3]) << 8) | int(x[4]);
      bool neg = raw & 0x800000;
      if (neg) raw ^= 0x800000;
      float temp = raw / 10000.0f;
      float hum = (raw % 1000) / 10.0f;
      float batt = x[5];
      if (neg) temp = -temp;
      id(livingroom_temperature).publish_state(temp);
      id(livingroom_humidity).publish_state(hum);
      id(livingroom_battery).publish_state(batt);
FRIDGE
  • mac_address: “AA:BB:CC:DD:EE:02”
    then:
    • lambda: |-
      float batt = x[5];
      id(fridge_temperature).publish_state(temp);
      id(fridge_humidity).publish_state(hum);
      id(fridge_battery).publish_state(batt);
FREEZER
  • mac_address: “AA:BB:CC:DD:EE:03”
    then:
    • lambda: |-
      float batt = x[5];
      id(freezer_temperature).publish_state(temp);
      id(freezer_humidity).publish_state(hum);
      id(freezer_battery).publish_state(batt);
SENSORS (MQTT AUTO-PUBLISH)
sensor:
  • platform: template
    name: “LivingRoom Temperature”
    unit_of_measurement: “°C”
    accuracy_decimals: 2
    name: “LivingRoom Humidity”
    unit_of_measurement: “%”
    accuracy_decimals: 1
    accuracy_decimals: 0
    name: “Fridge Temperature”
    name: “Fridge Humidity”
    name: “Freezer Temperature”
    name: “Freezer Humidity”
why don´t you use NodeRED? Import the sensors through MQTT?
I also have / had many special scripts - but with the growing features of NodeRED on Venus, i move more and more to plain MQTT
It sounds like ChatGPT has mixed you a cocktail of technologies and over complicated things.
Is the services.yml file you posted suppposed to be for dbus-mqtt-devices? If so I’m surprised it even runs.
it looks like you are trying to use ESPHome on your microcontrollers to talk to Victron.
If you want help with dbus-MQTT-devices can O ask you start a discussion of the GitHub discussion page for the project
Regards
Martin
If you aren’t sure how to do it, do not rely on AI then come here and ask the community to fix the hallucination.
Rather just ask for help.
Will do…thanks for the tip
I know diddly about NodeRED at the moment. I’ll start reading. One question, will it require more hardware than the venus the rpi and maybe a ESP32?
ron
no, you just have to install Benus OS Large, then you get NodeRED
The ESP32 you need as bridge to Govee Sensors
At first, install something like MQTT Explorer on your PC and check for MQTT Messages from the Bridge
You could use the MQTT Broker in Venus, but you have to send a keep-alive signal - could also be done by NodeRED
I wrote a program that will run directly on Cenus OS to bring Govee sensors in just like Ruuvi sensors.
I’m wrong in on cleaning it up for public release.
What Govee sensors are you using?
Very nice…I’m using HS5179 and H5111 for temp/humidity and the H5059 water sensors.
If you don’t mind sharing the code, even if it’s not clean…I’m interested in learning as much as I can at this point.
Ron
By cleaned up I mean removing my personal system specific stuff from it. I’m away from my system this week, but I’ll try to get something posted up when I get back.
