I have three multiplus units that are on a ve bus, the ac1 in is connected to an external ATS (100/4p) and the generator also. there is a cable from the Aux 1 on multiplus1 to the ATS voltfree (N O when grid is active). There is also a cable from the Cerbo to the gen start/stop. Prior to the generator installation the multiplus units are configured with a BYD box 15.4 to give AC1 out when grid goes down, AC2 out only connects when AC1 in is live. PV is also connected to ACout. I need to confirm that the wiring suitable and to change all the config system settings to allow for generator start/stop and operation at 10a when the grid is out, and back to 30a when grid returns. please walk me through what I need to do? Gemini AI is not suitable for these instructions. It gets the VE config assistant menus wrong.
Ok all done. Node Red programming used instead..
