Generator setup in Cerbo GX
When I plug into generator, power usage displays under shore on the cerbo gx display. Is there a change that would provide differentiation?
Unless it’s been updated, you’ll need to change a setting to match your source.
You can do it manually on a GX device here:
Or with Node-RED here:
Ac/In/0/Source:
The source connected to the first input,
0=not used, 1=Grid, 2=Generator, 3=Shore
Thanks so much for that. So after setting up ac 1 (shore) and ac 2 ( generator) , do you manually switch to the appropriate source depending on what you are connected to?
That selection can be changed with the 2 methods shown, and only changes the GUI display for the AC input #1 source.
My Multiplus 2x120 only has a single AC input. If you have 2 AC inputs, I’m not sure how that would work.
For a quattro you can se the inputs the same way in system setup you just have two options.
