Simple issue. My installation data is interpreting solar to battery as “consumption”. This will result in excess reserve of battery capacity left over in the morning as the system is expecting the battery to run out in the morning. I have localized the problem to my Fronius 10kW AC coupled inverter that is LAN connected to the cerbo.
I have programmed the Multiplus inverter’s ESS assistants to know that the PV inverter is located at the output side of the 3-phase MP2 5000 cluster.
Everything works as expected, Solar keeps producing even at power cuts, as the inverter is powered by the battery “UPS function” as is my entire house.
My question. How do I get the Victron Cerbo to NOT treat the PV Inverter as “Consumption” when the MPs are charging the batteries from the solar energy from Fronius?
Real consumption is about 1kWh, but the graphs show 5-6kWh as they are taking in the battery charging data as well.
The PV charger (Victron 450/200) does not act like this, so not additional “consumption” from there while charging.
I have spent 6 months trying to figure this out with all the menus and settings, but to no avail. Any advice would be appreciated.
