Throttling AC-coupled solar too hard
I’ve noticed that the Cerbo is throttling my Fronius inverters too hard when I’ve disabled “AC-coupled PV - feed in excess”, to the point that the Multiplus-II isn’t charging anywhere near it’s full capacity from the available PV. PV is on the AC-In side of the Multiplus-II.
For example, right now, I have about 5.5kW of solar outside - but with ESS set to “Optimised without Battery Life” and disabling excess PV feed-in, the Multiplus-II will charge the battery at around ~1.8kW, with the Fronius inverters throttled by the Cerbo down to keep the grid export as close to zero as possible (so as not to be charged for exporting).
If I switch feed-in excess back on, I’ll get ~3.3kW of charging, which is what my solar is able to supply.
I could live with a few hundred kW or something like that, but we’re talking 1.5kW of power going to waste. Is this expected behaviour or is there configuration I can adjust to get better efficiency from the throttling here? I don’t want to waste precious kW of charging when I am getting free power from the sun.
Thanks,
Andrew
To add - I notice that I normally leave my “Minimum SOC” at 5% - I’m happy to run my battery down each night if need be - this throttling is an issue. If I change my “minimum SOC” to, say, 100%, it’ll charge at full capacity and utilise all the available solar.
So it feels like I’m running into some “expected behaviour”, but I can’t make sense of why the system would choose to not charge at full capacity if sufficient solar exists to do so.
To wrap this up, more recent versions of the beta firmware have resolved this behaviour – it will charge with all available solar, even if it exceeds the scheduled SoC for the battery for that hour. This is a good result!
