Firefly Integration For Multiplus?
Ive got a Dynamax RV that has the Firefly system for tanks, lights, HVAC, generator control, etc…and a Magnum MagnaSine Hybrid Inverter. All that runs on RV-C.
Any chance that the Multiplus could one day replace the Magnum and be 100% functional in the Firefly?
Everything else in the power system is Victron, and I run a secondary Cerbo…but not having a Multiplus to tie it all together is not ideal.
What work would need to be done?
Add RV-C support in Multiplus?
Can the Cerbo GX act as a compatible bridge between the Multiplus and Firefly?
If not on the dev board, any chance it could be community built? (Im a dev & worked on the Mopeka integration) I know many of us are itching to go full Victron…but stuck behind Firefly. Its just not possible to change all the hardware…
