[Feature Request] VM-3P75CT - independent channels meter - role per channel
Hi Victron
I see a value of changing firmware of https://www.victronenergy.ua/meters-and-sensors/energy-meter VM-3P75CT to become 3 channels independent meters.
Reason - I have a HeatPump ( single phase ), Boiler(single phase), Water Pumps(4 items, all single phase ).
Instead of buying 6 other meters (e.g ET112) and rebuilding whole electrical box having 2 VM-3P75CT with hooked up 6 CTs would be a great solution with minimum investment and effort.
For that assigning role per channel/phase would be a great solution programatically.
Thank you in advance
You can view data on the individual each lines already in VRM in a custom widget. Allowing custom names would be nice option.
This is not about viewing the data per phase. It’s easy as you said
This is about assigning meter roles per phase, like heater on phase 2 and heatpump on phase 3
Hi, is there any news on this ? I have the same question , using the 3 phases separetly for 3 different loads/pv.
Seems like this request is getting more likes , good
