[FEATURE REQUEST] mutiplus 2 idle state in ESS,
To overcome the problem I wrote a couple of automations in home assistant, they are running from more then a weeks now.
The basic intention is to retain all the ESS functions, to achieve this I’m switching between ESS external control (where the multiplus goes in passthough) and ESS mode 1 depending on the situation, this way I don’t have to write the complete control loop.
There are four main conditions:
  1. set multiplus to idle: when battery power is between -20 and 20 for more then 30 seconds, set ess external mode: slave 100 address 2902 value 3, and set multiplus address 38 to 0, this enable the multiplus to charge the battery if needed. But remains off otherwise.
  2. set back to ESS m1 for self consuption: when power from the grid is above 100W, and battery SOC is above minimum sock battery life level (if you use battery life otherwise just minimum level) , then put back ESS in mode 1.
  3. set back to ESS m1 for peak shaving: when power from the grid is above your grid limit and battery SOC is above 0%, then put back ESS in mode 1.
  4. set back to ESS m1 for charging: when battery SOC is lower then minimum sock battery life level (if you use battery life otherwise just minimum level) or when grip power lower then -100 and battery lower then 95%, then put back ESS in mode 1.
During this week I didn’t noticed strange behaviours and the multiplus can finally rest when not needed.
