Small feedback after 4 days of use, the first 3 days there wasn’t any situation for the new logic to kick in and everything worked as expected, today there was low solar with random spikes and the new “selfconsume_accept_charge” helped harvesting every bit of solar excess.
For the spikes of 10KW grid pull, I see the exact same behaviour when I switch from ESS mode 3 to ESS mode 1 with DESS enabled. When I switch from ESS mode 3 to 1 without DESS this spikes doesn’t occur.
They are just 3-5 seconds, so nothings too concerning.
I keep mode 3 when the multiplus is idling to keep idle power at 7 watts instead of 30-40 Im doing it via modbus commands, would be nice if the GX can do it on its own.
I’ve explained the behaviour here.
